Knowledge Base Article
Why are the out_valid and out_data of the CIC Intel® FPGA IP stuck at 0 when the "Number of stages" parameter is of a power of 2?
Description
Due to a problem with the CIC Intel® FPGA IP in Intel® Quartus® Prime version 18.1 software, you may observe the above problem if the value of "Number of stages" is of power of 2 and the "Filter type" is Interpolator.
Resolution
There is no workaround for this problem. This problem will be fixed in a future version of the Intel® Quartus® Prime software.
Updated 3 months ago
