Knowledge Base Article
Error(14394): Verilog HDL error at <module_name>.sv(<line>): vector/single is not declared under the prefix ""
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1.1 or earlier, you might see this error when synthesizing the SystemVerilog HDL code where a typedef struct declared inside an interface is referenced within a nested submodule.
The SystemVerilog HDL code as below:
interface my_interface
parameter int WIDTH = 1
typedef struct packed {
logic single;
logic [WIDTH-1:0] vector;
} MY_STRUCT;
logic req;
logic ack;
MY_STRUCT data;
modport src
output req,
input ack,
output data
modport dst
input req,
output ack,
input data
endinterface
module testmodule
input wire clock,
my_interface.dst data_in,
my_interface.src data_out
typedef data_in.MY_STRUCT ITYPE;
typedef data_out.MY_STRUCT OTYPE;
ITYPE demo_in;
OTYPE demo_out;
assign demo_in = data_in.data;
assign data_out.data = demo_out;
submodule my_sub
.data_in ( demo_in ),
.data_out ( demo_out )
module submodule
input ITYPE data_in,
output OTYPE data_out
endmodule
endmodule
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 26.1, download and install the patch 0.37 below.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 1 month ago
Version 2.0
