13 years agoFiles seem to be missing from Qsys synthesis of UP entities
Gentlemen,
I am working on a Qsys project involving the UP 16x2 LCD display and 3 UARTS on a DE2-70 board. The Qsys generation of the NIOS processor works fine with no errors or warnings. However, when I instantiate the NIOS processor in my project, it cannot find 4 modules: altera_up_character_lcd_communication altera_up_character_lcd_initialization altera_up_RS232_in_deserializer altera_up_RS232_out_serializer I have looked everywhere and cannot seem to find them. I am running Quartus II 11.0 sp1. Any assistance would be gratefully appreciated. Regards, Geoffrey Gill7 Replies
Did you install the University Program IP cores? They're a separate download.
http://www.altera.com/education/univ/software/upds/unv-upds.html Cheers, Dave - Altera_Forum
Dave,
In short, yes. I have a separate directory under C:\altera\11.0sp1\University_Program. There is the Monitor program, Examples, etc. I have been able to load and play with both the Basic Computer and the Media Computer for the DE2-70 board. I have been able to make some minor changes to the Basic Computer. I did that using the SOPC Builder, but was trying to use Qsys, as that seems to be the future. I have found Qsys somewhat more complex in terms of requiring many more "connections". SOPC Builder seemed to make more interconnects automatically. I am not a "hardware designer", but am trying to develop a simple computer to control a Serial Graphics Display, a DCC model railroad, and incoming XBee communications from the trains. The alternative choice is to use an ATMega 128, but I thought the inherently better built-in I/O on the DE2-70 board would make life easier. Any other ideas on why this might be failing? I will try to reinstall the UP cores and recompile the project. Thanks for taking the time to respond. Regards, Geof - Altera_Forum
Dave,
I uninstalled the UP, then completely reinstalled it. No joy. When I instantiate the NIOS processor and compile it fails again with the same error messages. Regards, Geof - Altera_Forum
Dave,
I removed the UP IP's from the Qsys project and used the regular Altera ones. I left out the LCD display, but added the 3 serial ports. It generated the system with 6 warnings and then it compiled. So who knows. Also FYI the RS232 UP IP core has an error in it. It will not allow the selection of a 19200 baud rate! I was able to recalculate the BAUD_TICK_COUNT, etc to force it to 19200. Weird. Geof - Altera_Forum
Hi Geof,
Sorry to hear the UP cores didn't work. I haven't ever had a need to try them. Creating a Qsys/SOPC IP core is pretty straight-forward once you get the hang of it. If you create the core yourself, then you're only fixing your own bugs :) It sounds like you've figured out a work-around that will get you going. If you have trouble figuring out how to get things to work, ask and I'll take a look. Cheers, Dave - Altera_Forum
Thanks, Dave,
I have run into one more issue. I am using the web edition of he Quartus II software. Am I correct is assuming that I cannot use the NIOS processor except on a tethered or time limited basis without a separate license? That is a real deal breaker for using this approach. My fallback position for using either my DE0-NANO or DE2-70 board is to do everything in Verilog. I am a retired individual and could not justify a great expense for a license. I appreciate again the time you have spent of this issue. One of the great benefits of forums like this. Regards, Geof PS: with the Cheers signoff are you an Aussie? - Altera_Forum
--- Quote Start --- I have run into one more issue. I am using the web edition of he Quartus II software. Am I correct is assuming that I cannot use the NIOS processor except on a tethered or time limited basis without a separate license? --- Quote End --- Use the NIOS II/e core: http://www.altera.com/devices/processor/nios2/cores/economy/ni2-economy-core.html --- Quote Start --- That is a real deal breaker for using this approach. My fallback position for using either my DE0-NANO or DE2-70 board is to do everything in Verilog. I am a retired individual and could not justify a great expense for a license. --- Quote End --- If the NIOS II/e core doesn't work for you, you could try one of the OpenCores cores, eg., OpenRISC or one of the AVR variants, or the Leon SPARC processor. They're all free. --- Quote Start --- with the Cheers signoff are you an Aussie? --- Quote End --- Close - NZer (Kiwi) :) Cheers, Dave
