13 years agoFiles seem to be missing from Qsys synthesis of UP entities
Gentlemen, I am working on a Qsys project involving the UP 16x2 LCD display and 3 UARTS on a DE2-70 board. The Qsys generation of the NIOS processor works fine with no errors or warnings. However,...
13 years ago --- Quote Start --- I have run into one more issue. I am using the web edition of he Quartus II software. Am I correct is assuming that I cannot use the NIOS processor except on a tethered or time limited basis without a separate license? --- Quote End --- Use the NIOS II/e core: http://www.altera.com/devices/processor/nios2/cores/economy/ni2-economy-core.html --- Quote Start --- That is a real deal breaker for using this approach. My fallback position for using either my DE0-NANO or DE2-70 board is to do everything in Verilog. I am a retired individual and could not justify a great expense for a license. --- Quote End --- If the NIOS II/e core doesn't work for you, you could try one of the OpenCores cores, eg., OpenRISC or one of the AVR variants, or the Leon SPARC processor. They're all free. --- Quote Start --- with the Cheers signoff are you an Aussie? --- Quote End --- Close - NZer (Kiwi) :) Cheers, Dave
