13 years agoFiles seem to be missing from Qsys synthesis of UP entities
Gentlemen, I am working on a Qsys project involving the UP 16x2 LCD display and 3 UARTS on a DE2-70 board. The Qsys generation of the NIOS processor works fine with no errors or warnings. However,...
13 years agoHi Geof,
Sorry to hear the UP cores didn't work. I haven't ever had a need to try them. Creating a Qsys/SOPC IP core is pretty straight-forward once you get the hang of it. If you create the core yourself, then you're only fixing your own bugs :) It sounds like you've figured out a work-around that will get you going. If you have trouble figuring out how to get things to work, ask and I'll take a look. Cheers, Dave
