HPark14
1 month agoWhy Generic Component are included in my GHRD?
Hi, Altera I am a Dist. FAE in Uniquest Korea. When building the Agilex 5 GHRD on a Linux OS, as you can see, the IPs are recognized as generic components. It would be great if an upgrade could fi...
- 1 month ago
Hi Hudson,
In the past, whenever I ran into that issue (component footprint mismatch detected), running 'Sync System Info' helped me to recover the component.
Could you give it a try and see if it works for you?
If it doesn't help, could you share which Quartus and GHRD version are you using? Sharing the link from where you are downloading the GHRD would be helpful to reproduce the issue in my side.
HPark14
24 days agoHi Hector
I tried the method you suggested and it worked. Thank you!
I always used the Auto option.
SueC_Altera
Contributor
23 days agoThanks for reporting back, HPark14. It's always good to know what solved the problem!
