Motaz_sami
6 months agoU-Boot "Synchronous Abort" boot failure on Terasic Atum A5 Rev B via Quartus 24.3 .jic generation
I am reaching out for technical assistance regarding a reproducible boot failure on the Terasic Atum A5 Rev B development board (Agilex 5) when using Quartus Prime Pro 24.3. I am attempting to compi...
JamesG_Altera
6 months agoI have some questions about the process you have followed:
- What command did you use to merge the .hex with the SOF? Did you use the command found in sof_with_hps.bat supplied by Terasic?
- What command did you use to generate the JIC file from the SOF? Did you use the command found in sof_to_jic.bat supplied by Terasic?
- Your U-boot SPL comes from the hex file supplied by Terasic, in the GHRD source tree. But where does your full U-Boot software come from?
Motaz_sami
6 months agoEverything I used was the standard ,that shipped with the board from terasic
