Stratix 10 HPS LED example
- 5 months ago
We are using Quartus 26.1 for all these activites.
thank you for the feedback.
You are right, i cant add any attachment too.
I will feedback that to the team.
I recommend comparing your .qsf file against the version provided in the zip file here:
For the DDR4 pins, the user may also need to manually assign the corresponding pins in the .qsf file.
If you are using both HPS and EMIF, I recommend starting from the example here as a baseline:
- ShunJingG_Altera5 months ago
Regarding the attachment, I have rechecked it. Please kindly rename the .rpt file to .txt before uploading.
I can attach a zip file.
- Sajeev_antony5 months ago
Fitter report attached.
Also can you help me to get started with the GSRD. How to generate the Quartus project from the GSRD. Coun't find any Quartus project file in it.
You may kindly refer this latest fitter report file from Quartus 26.1
