neveruse_altera_again
2 years agoRiscFree Cyclone V Example Project Building Failed
Hi, Just installed the newest version RiscFree IDE to learn Cyclone V HPS software. Imported the example project, but found out the project cannot build correctly. The console showed Nothing to bu...
- 2 years ago
Found the cause of this issue, which is that the RiscFree for Intel does not come with ARM cross compiler and related toolchain. After weeks' trial with ARM DS, RiscFree and GNU MCU Eclipse, I feel that ARM DS works fine but with expensive license, RiscFree with ARM toolchain as well as GNU MCU Eclipse can compile and connect to usb blaster wherase I still cannot go through the gdb process. I will turn to Zynq.
aikeu
2 years agoneveruse_altera_again
2 years agoHello Aik,
Thank you for your reply. I have no issue with ARM DS on compiling and debugging, but concerning the licensing I would try the RiscFree if it supports Cyclone V HPS. I guess for now I have to use ARM DS for evaluation.
Zihan Gao
