neveruse_altera_again
2 years agoRiscFree Cyclone V Example Project Building Failed
Hi, Just installed the newest version RiscFree IDE to learn Cyclone V HPS software. Imported the example project, but found out the project cannot build correctly. The console showed Nothing to bu...
- 2 years ago
Found the cause of this issue, which is that the RiscFree for Intel does not come with ARM cross compiler and related toolchain. After weeks' trial with ARM DS, RiscFree and GNU MCU Eclipse, I feel that ARM DS works fine but with expensive license, RiscFree with ARM toolchain as well as GNU MCU Eclipse can compile and connect to usb blaster wherase I still cannot go through the gdb process. I will turn to Zynq.
aikeu
2 years agoHi zihangao,
My attempts for HPS compilation was using linux environment to get the specific compilers.
I think the links below may help:
https://www.rocketboards.org/foswiki/Documentation/SoCEDS
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10
Aik EU
