torstein18
2 months agoStore custom keys on SDM Agilex3
Hi I know it's possible to store encryption and siging keys on the SDM for fpga firmware decryption and authentication, but is it possible to store my own keys on it? I will use the key to decr...
SueC_Altera
Contributor
1 month agoTesting to see if I can post the link now:
SueC_Altera
Contributor
1 month agoTesting to see if I can post the link:
- torstein181 month ago
It is the link to the hardware design inside the tutorial I need (GHRD), for quartus 26.1.1 and this devkit DK-A5E013BM16AEA: Agilex® 5 FPGA E-Series 013B Development Kit
When I try to program the certificate to the SDM I get this error:
quartus_pgm -c 2 -m jtag -o "p;signed_prov_srk.ccert" Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 26.1.1 Build 130 08/06/2026 SC Pro Edition Info: Copyright (C) 2026 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and any partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus Prime License Agreement, Info: the Altera IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Altera and sold by Altera or its authorized distributors. Please Info: refer to the Altera Software License Subscription Agreements Info: on the Quartus Prime software download page. Info: Processing started: Thu Oct 1 10:37:03 2026 Info: System process ID: 532113 Info: Command: quartus_pgm -c 2 -m jtag -o p;signed_prov_srk.ccert Info (213045): Using programming cable "USB-Blaster [1-1]" Info (209060): Started Programmer operation at Thu Oct 1 10:37:04 2026 Info (19096): Programming compact certificate at device index 1 Error (19117): Programming failed on device index 1. The certificate is invalid or the device does not support the certificate. (Error Code 0x80). The certificate is invalid. (Process Status 0xF00000FF) Error (209012): Operation failed Info (209061): Ended Programmer operation at Thu Oct 1 10:37:04 2026 Error: Quartus Prime Programmer was unsuccessful. 2 errors, 0 warnings Error: Peak virtual memory: 626 megabytes Error: Processing ended: Thu Oct 1 10:37:04 2026 Error: Elapsed time: 00:00:01 Error: System process ID: 532113- torstein181 month ago
I had to change the command from: quartus_pfg --ccert -o ccert_type=PROV_SERVICE_ROOT_KEY -o ccert_device=A3CW135BM16AE6S certificated/unsigned_prov_srk.ccert To this: quartus_pfg --ccert -o ccert_type=PROV_SERVICE_ROOT_KEY_UDS_EFUSE -o ccert_device=A3CW135BM16AE6S -o non_volatile=OFF certificates/unsigned_prov_srk.ccert Then I was able to program the certificate on an Agilex3 device- BoonBengT_Altera1 month ago
Moderator
Hi torstein18 ,
Greetings. I am writing to follow up on the previous clarification and to check whether you have had an opportunity to review it.
I look forward to hearing from you at your convenience.
Best Wishes
BB
