torstein18
2 months agoStore custom keys on SDM Agilex3
Hi I know it's possible to store encryption and siging keys on the SDM for fpga firmware decryption and authentication, but is it possible to store my own keys on it? I will use the key to decr...
SueC_Altera
Contributor
2 months agoHi torstein18,
Do you have an NDA with Altera? The Agilex 3 Device Security User Guide tells you how to do this, but it is a restricted document, so you have to have an NDA and be signed into MyAltera to get access.
Sue
- torstein182 months ago
Ok, I will check it out when I get an NDA
- torstein181 month ago
I have read trough the documentation, but I still don't understand how I can send commands to the SDM from linux running on the HPS. Do I need to install any drivers or do some changes to the device tree. Here is the device tree node I have for the SDM:
firmware { svc { compatible = "intel,agilex5-svc"; method = "smc"; memory-region = <&service_reserved>; iommus = <&smmu 10>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; interrupt-parent = <&intc>; altr,smmu_enable_quirk; fpga_mgr: fpga-mgr { compatible = "intel,agilex5-soc-fpga-mgr"; altr,smmu_enable_quirk; }; temp_volt: hwmon { compatible = "intel,soc64-hwmon"; }; fcs_config: fcs-config { compatible = "intel,agilex5-soc-fcs-config"; }; }; };I have installed the FCS driver:
root@agilex3:~# zcat /proc/config.gz | grep FCS CONFIG_ALTERA_SOCFPGA_FCS_DEBUG=y CONFIG_CRYPTO_DEV_INTEL_FCS=yIs there any other drivers I need?
- SueC_Altera1 month ago
Contributor
Hi torstein18 - please take a look at this example:
I have to put a screen shot instead of a link get around the forum restrictions. It is on altera-fpga.github.io
Sue
