The system will still be stable but just the throughput will be throttled and the system might not perform as expected.
Are you trying to check the cache is enabled in the HPS? If so, in linux you could use the "free -h" command to see the available cache size.
For latest test I had committed.
I am streaming camera data and forwarding to monitor ouput.
It can be free run completely w/o distro intervein.
Based on the above background when the input stream data is 90M and h2fsdram uses 100M on issue.
However once I increase the clock from 100 ->148 then the distro terminal stall and serial port no longer responds.
But the monitor forward shows the internal operation is working properly which means camera stream is forwarding to monitor w/o issue each frame is shown properly.
The major issue here is why distro now got stall and stuck and completely dead?
Brian
