Thank you for your interest BoonBengT_Altera in my case. I am documenting all the issues I encounter in this thread, so any help or suggestions are welcome.
Hi angelsz15,
What remaining questions or concerns do you have?
Sue
- angelsz151 month ago
Hi SueC_Altera
I am currently working with a Kinect V1 (Xbox 360 Model 1414) using the Arria 10 SoC GSRD. At the moment, the system correctly detects the hardware (camera, motor, and audio are listed in lsusb). However, I am experiencing failures when initiating communication with the device, including USB transfer errors, incomplete reads, and unexpected disconnections.
I have ruled out permission issues (running as root and udev rules applied), so I suspect the root cause may be related to limitations of the USB controller (dwc2), bus saturation, or hardware constraints for handling isochronous transfers.
As a reference, I have tested with standard USB 2.0 webcam devices, and in those cases I am able to communicate with them and stream video without issues.
Full console output attached:
root@arria10-ea700498022f:~/app# ./kinect_test_app
send_cmd: Input control transfer failed (18)
[ 340.405365] usb 1-1.3: USB disconnect, device number 7
freenect_fetch_reg_info: send_cmd read 18 bytes (expected 118)
send_cmd: Output control transfer failed (-1)
freenect_fetch_reg_const_shift: send_cmd read -1 bytes (expected 8)
freenect_camera_init(): Failed to fetch const shift for device
Device 0x51fda0 open during shutdown, closing...
root@arria10-ea700498022f:~/app# [ 343.517208] usb 1-1.3: new high-speed USB device number 8 using dwc2
root@arria10-ea700498022f:~/app# lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc2/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 4, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=, 12M
|__ Port 3: Dev 8, If 0, Class=Vendor Specific Class, Driver=, 480M
Bus 001 Device 008: ID 045e:02ae Microsoft Corp. Xbox NUI Camera
Bus 001 Device 003: ID 045e:02b0 Microsoft Corp. Xbox NUI Motor
Bus 001 Device 004: ID 045e:02ad Microsoft Corp. Xbox NUI Audio
Bus 001 Device 002: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Hi SueC_Altera
