mmc blocks written = error
Hi Gokulraj,
Sorry for the delay in getting back, was checking with our factory apps on this.
Apparently this is a known issue as there is another case with similar issue, quote from the other case findings
- MMU table missing the mapping for higher memory bank, and the issue only being seen with dcache turn on, as this would trigger MMU run, and when MPU access those memory region not defined in MMU table mapping would causing system hang
- With logical block enable, the default logic memory layout would set reserve to higher memory region, hence any feature like sf, tftp and wget which calling lmb check would prevent MPU to access higher memory region
I've attached the Patches.zip file here but it is based on the latest build thus might not be compatible if you're running an older version of the code.
You can try to manually edit the files indicated here (add in those in green) and rebuild uboot fsbl and itb (or you can refer to the patches on the changes)
Kian
Here the main issue is in reading 64bit memory address.
"mmc write" command can take 32bit memory address and its is working fine,but while using 64bit memory address it's locked in timeout error. I've confirmed it by debugging the u-boot code while using "mmc write" command.
will you check with the files related to mmc in driver and include folder in your side and give me a solution.
Gokul raj
