Inquiry on CVE-2026-98432 Patch Schedule, Custom Backport Support, and PSIRT Vulnerability Policy
Hello Altera Support Team,
One of our key customers is currently preparing compliance documentation (including EU Cyber Resilience Act / security audit requirements) and inquired about the status and handling policy for Linux kernel vulnerability CVE-2026-98432 (IPv4 TCP use-after-free, CVSS 9.8).
We verified that in the upstream Linux kernel, this vulnerability was resolved in the 6.18.56 stable release by replacing kfree() with kfree_rcu() in inet_sock_destruct() (net/ipv4/af_inet.c) and tcp_v4_reqsk_destructor() (net/ipv4/tcp_ipv4.c). However, on the current `socfpga-6.18.37-lts` branch in `github.com/altera-fpga/linux-socfpga` (used in GSRD 26.3), both functions still use kfree().
To provide an official response to our customer, please confirm the following three items:
- Patch Plan & Release Schedule for CVE-2026-98432
- Is there a plan to include the fix for CVE-2026-98432 in `linux-socfpga` / GSRD?
- If yes, in what form will it be delivered (e.g., rebasing to upstream 6.18.56 or later in the next GSRD release, or a patch update on top of 26.3), and what is the estimated release timeline? - Support Scope for Customer-Applied Backport via Yocto Layer
- Until an official Altera kernel update is available, our customer plans to backport the upstream 6.18.56 patch onto `socfpga-6.18.37-lts` via their custom Yocto layer.
- Does Altera recommend this approach, and will applying this upstream network-stack patch impact Altera's official technical support scope for SoC hardware and Altera IP drivers? - Altera Security Vulnerability (PSIRT) Management & Upstream Sync Policy
- Where are official security advisories (PSIRT) for GSRD and `linux-socfpga` published? (Is it managed exclusively via the Altera Product Security Advisories portal, or is there a separate mailing list/feed for `linux-socfpga`?)
- What is Altera's standard cadence and SLA/lead time for integrating upstream Linux LTS security patches into `linux-socfpga` and GSRD releases? (Our customer requires this policy description as official evidence for their vulnerability management framework.)
Thank you in advance for your prompt review and confirmation.
Hudson
- tehjingy_Altera
Hi
Please give us sometime to work out the details and get back to you on this. - ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
