F_A_A's avatar
F_A_A
5 months ago
HPS SDRAM Calibration Failed
To whom it may concern,
The HPS of a Cyclone V SoC based board that I designed is failing the booting process. In which the following error message is outputted to the console:
U-Boot SPL date and time
SDRAM Calibration Failed.
ERROR ### Please Reset the board ###
I’m trying to determine the cause of the SDRAM calibration failure by enabling calibration reporting as indicated in:
https://www.intel.com/content/www/us/en/docs/programmable/683841/17-0/enabling-the-debug-report-for-arria.html
https://www.intel.com/content/www/us/en/docs/programmable/683841/17-0/determining-the-failing-calibration.html
but I’m only getting the above mentioned message without an indication of the failing SDRAM stage and cause.
please advise on how to get the preloader to output debug insights to the console. Please note that the approach described in the link below was used to create the Preloader:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10
Also, please advise on the sequence of failure messages that are outputted by the Preloader.
  • KianHinT_altera's avatar
    KianHinT_altera
    Hi F_A_A​ ,
    Just checking up on this case issue as it has been idling for some time, is the issue resolved on your end or do you have some logs per Alan questions?
    Kian
  • AlanCLTan's avatar
    AlanCLTan
    Hi F_A_A,
    Do you have any successful boot-up before?
    Any chance for you to try to get the debug log working?
    SEQ.C: Calibration Failed
    SEQ.C: Error Stage : <Num>
    SEQ.C: Error Substage: <Num>
    SEQ.C: Error Group : <Num>
    Alan
    AlanCLTan
    Do you have any design which successfully booted on your device? Or is this your first try?
    First thing to do is to isolate the problem, is it possible to boot a basic design (like the GSRD in the links you have)?
  • Hello F_A_A
    Please try running the EMIF-only example design.
    At this point, it’s not clear whether the error is caused by an HPS configuration issue or an incorrect EMIF configuration.
    To rule out any EMIF-related configuration problems, please make sure the standalone EMIF example design runs successfully on its own.
    • F_A_A's avatar
      F_A_A
      Dear CaroG,
      Thanks for the reply.
      Please correct me if I’m wrong but the Cyclone V’s HPS component in platform designer is integrated with the EMIF IP. Thus, I don’t think it is possible to run the design as EMIF only. Kindly, advise.
