F_A_A
1 year agoHPS SDRAM Calibration Failed
To whom it may concern, The HPS of a Cyclone V SoC based board that I designed is failing the booting process. In which the following error message is outputted to the console: U-Boot SPL date an...
CaroG_Altera
1 year agoHello F_A_A
Please try running the EMIF-only example design.
At this point, it’s not clear whether the error is caused by an HPS configuration issue or an incorrect EMIF configuration.
To rule out any EMIF-related configuration problems, please make sure the standalone EMIF example design runs successfully on its own.
- F_A_A1 year ago
Dear CaroG,
Thanks for the reply.
Please correct me if I’m wrong but the Cyclone V’s HPS component in platform designer is integrated with the EMIF IP. Thus, I don’t think it is possible to run the design as EMIF only. Kindly, advise.
