F_A_A
1 year agoHPS SDRAM Calibration Failed
To whom it may concern, The HPS of a Cyclone V SoC based board that I designed is failing the booting process. In which the following error message is outputted to the console: U-Boot SPL date an...
CaroG_Altera
1 year agoHello F_A_A
Please try running the EMIF-only example design.
At this point, it’s not clear whether the error is caused by an HPS configuration issue or an incorrect EMIF configuration.
To rule out any EMIF-related configuration problems, please make sure the standalone EMIF example design runs successfully on its own.
F_A_A
1 year agoDear CaroG,
Thanks for the reply.
Please correct me if I’m wrong but the Cyclone V’s HPS component in platform designer is integrated with the EMIF IP. Thus, I don’t think it is possible to run the design as EMIF only. Kindly, advise.
