How to program FPGA in Arria 10 HPS?
- 2 years ago
Hi sunyeong,
You can refer to this document on building the bootloader method using Arria10:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10
Arria 10 FPGA configuration is done in two steps:
Configuration of periphery(periph.rbf): this allows HPS DDRAM to be brought up, and must do be done in SPL
Configuration of fabric(core.rbf): it configures the actual FPGA core fabric, and can be done from SPL or U-Boot
Aik Eu
Hi, Aik Eu.
Thanks for your comments.
Okay, I understand that you mentioned.
core.rbf: related to FPGA design
periph.rbf: related to DDR to work first in order to boot up properly.
I previously mentioned that there is an error in u-boot.
The logic of uploading rbf files was skipped because of mismatch configuration name. But error log is not printed.
(u-boot-socfpga/drivers/fpga/socfpga_arria10.c)
static int first_loading_rbf_to_buffer(struct udevice *dev, struct fpga_loadfs_info *fpga_loadfs, u32 *buffer, size_t *buffer_bsize, size_t *buffer_bsize_ori) { //... for (i = 0; i < count; i++) { images_noffset = fit_conf_get_prop_node_index(buffer_p, confs_noffset, FIT_FPGA_PROP, i); uname = fit_get_name(buffer_p, images_noffset, NULL); if (uname) { debug("FPGA: %s\n", uname); if (strstr(uname, "fpga-periph") && // "fpga-periph-1" in fit_spl_fpga.its (!is_fpgamgr_early_user_mode() || is_fpgamgr_user_mode() || is_periph_program_force())) { fpga_node_name = uname; printf("FPGA: Start to program "); printf("peripheral/full bitstream ...\n"); break; } else if (strstr(uname, "fpga-core") && // "fpga-core-1" in fit_spl_fpga.its (is_fpgamgr_early_user_mode() && !is_fpgamgr_user_mode())) { fpga_node_name = uname; printf("FPGA: Start to program core "); printf("bitstream ...\n"); break; } } schedule(); } if (!fpga_node_name) {//foga_node_name is null. debug("FPGA: No suitable bitstream was found, count: %d.\n", i);//because of log level, this log is not printed. return 1; } //... }
Don't care about that.
I am trying to upload rbf files using u-boot command.
This is related to #option1 that you mentioned.
The documentation explains how to upload rbf files using sd card.
But, I can't use sdmmc dauter card, and I am using QSPI boot mode.
So, Is there any way to load rbf files using usb?
Thank you.
Jung.
Hi, Aik Eu.
I use tftp command for uploading rbf file.
tftp ${loadaddr} fit_spl_fpga.itb imxtract ${loadaddr} fpga-core ${coreaddr} fpga load 0 ${coreaddr} ${filesize}
The document that you mentioned said that should upload core.rbf file.
But, in u-boot, uploading core.rbf file is skipped because of below code.
/* This function is used to load the core bitstream from the OCRAM. */ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) { //... if (rbfinfo.section == core_section && !(is_fpgamgr_early_user_mode() && !is_fpgamgr_user_mode())) { debug("FPGA : Must be in early release mode to program "); debug("core bitstream.\n"); return -EPERM; } //... }
Which rbf file should I upload? (core.rbf? periph.rbf?)
I tried periph.rbf, it works properly without error log.
Jung.
