BrianSune_Froum
Contributor
5 months agoCyclone V HPS FPGA2SDRAM Clock Queries
Dear Intel and all,
Having some very puzzling behavior on HPS SDRAM and FPGA fabric bridge.
If a fast clock i.e. 148MHz is running on 128bit AXI3 aka f2h_sdram0 mostly read action.
And another AXI3 is using the remain 128bit bus with 144MHz aka f2h_sdram1 mostly on write.
As such the system will stuck on distro aka Linux.
With all these background could engineer or internal stuffs help.
What is the restriction or constraints to use these bus under safe and stable speed?
Forgot to provide stable situation:
If the write dominated bus is reduced to 100MHz then the system is stable and no stall is found.
So this makes a very strong feeling that the write cache is having issue? maybe CMA insufficient?
Brian
