Building Yocto for FPGA boot first config on Agilex 7
Hello.
I work with Intel Agilex ® 7 FPGA I-Series Transceiver-SoC Development Kit and AGIB027R31B1E2VR0 device. I need to build rootfs image. I've tried a guide I'd found on rocketboards (https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRDSIAGI027) and with this guide i was able to build an sd card image with my own fpga bitstream file. But this guide is for HPS boot first config and now I need to create SD image for FPGA boot first config.
I was able to create .jic file, write it to QSPI flash and get FPGA configured from it after power up. Now it is a bit unclear for me how to modify Yocto building flow to disable FPGA configuration from U-Boot SSBL. Do you have any information about this?
- Jeet14
I am not able to open the shared link, it is broken. please resend once again.
Tiwari
- Mikhail_a
- Jeet14
From uboot you can configure the fpga using the below command-
Unfortunately we don't have such command to disable or reset the fpga configuration from the uboot.
Jeetesh
- Mikhail_a
Hello Jeetesh
Thank you for the link you've sent. But the problem is that I need to disable booting FPGA on SSBL stage and I couldn't find where is it can be disabled in U-Boot while compiling sd card image with Yocto.
I could only find something that controls booting process in file:
gsrd_socfpga/meta-intel-fpga-refdes/recipes-kernel/linux/linux-socfpga-lts/fit_kernel_agilex_fm87.its
fpga-4 { description = "FPGA bitstream for GHRD"; data = /incbin/("./ghrd.core.rbf"); type = "fpga"; arch = "arm64"; compression = "none"; load = <0xA000000>; hash { algo = "crc32"; };And during booting it can bee seen in a log
## Loading fpga from FIT Image at 02000000 ... Trying 'fpga-4' fpga subimage Description: FPGA bitstream for GHRD Type: FPGA Image Compression: uncompressed Data Start: 0x0283c534 Data Size: 3350528 Bytes = 3.2 MiB Load Address: 0x0a000000 Hash algo: crc32 Hash value: a4fe125a Verifying Hash Integrity ... crc32+ OK Loading fpga from 0x0283c534 to 0x0a000000 ....Error sending bitstream! ....Error sending bitstream! FPGA image is corrupted or invalid SCRIPT FAILED: continuing... ** Unable to read file / ** Failed to load '/'
- Jeet14
Are you looking for when board boots up from the SD card, it only runs the uboot and kernel and it should not load bitfile while booting?
Tiwari
- Mikhail_a
Hello!
Yes this is exactly what i'm looking for as at the moment of booting from SD card I already have the FPGA configured.
- Jeet14
Please follow the below link on Build SD Card Image-
In this above link it guide us on sd card image creation with multiple files like- u-boot.itb, Image, socfpga_agilex_socdk.dtb, ghrd.core.rbf.
In you case while creating SD card image don't include the .rbf file. and when you board booted up at u-boot run the fpga load command to configure the bitfile.
Tiwari
- Mikhail_a
Hello Tiwari
Thank you for this link. I'm going to try it and see if it works for me.
- Jeet14
I believe your enquiry has been answered. With that, I now transition this thread to community support.
Thank you.
Tiwari
- Mikhail_a
Yeap I managed to build Yocto with FPGA boot first config.
Thank you.
