Mikhail_a
3 years agoBuilding Yocto for FPGA boot first config on Agilex 7
Hello. I work with Intel Agilex ® 7 FPGA I-Series Transceiver-SoC Development Kit and AGIB027R31B1E2VR0 device. I need to build rootfs image. I've tried a guide I'd found on rocketboards (https://ww...
Jeet14
3 years agoHi,
From uboot you can configure the fpga using the below command-
Unfortunately we don't have such command to disable or reset the fpga configuration from the uboot.
Jeetesh
Mikhail_a
3 years agoHello Jeetesh
Thank you for the link you've sent. But the problem is that I need to disable booting FPGA on SSBL stage and I couldn't find where is it can be disabled in U-Boot while compiling sd card image with Yocto.
I could only find something that controls booting process in file:
gsrd_socfpga/meta-intel-fpga-refdes/recipes-kernel/linux/linux-socfpga-lts/fit_kernel_agilex_fm87.its
fpga-4 { description = "FPGA bitstream for GHRD"; data = /incbin/("./ghrd.core.rbf"); type = "fpga"; arch = "arm64"; compression = "none"; load = <0xA000000>; hash { algo = "crc32"; };
And during booting it can bee seen in a log
## Loading fpga from FIT Image at 02000000 ... Trying 'fpga-4' fpga subimage Description: FPGA bitstream for GHRD Type: FPGA Image Compression: uncompressed Data Start: 0x0283c534 Data Size: 3350528 Bytes = 3.2 MiB Load Address: 0x0a000000 Hash algo: crc32 Hash value: a4fe125a Verifying Hash Integrity ... crc32+ OK Loading fpga from 0x0283c534 to 0x0a000000 ....Error sending bitstream! ....Error sending bitstream! FPGA image is corrupted or invalid SCRIPT FAILED: continuing... ** Unable to read file / ** Failed to load '/'
