keloke98
9 months agoArria 10 SoC Dev Kit Baremetal HPS examples issue & workflow
Hi, I recently acquired an Arria 10 SoC dev kit but I'm really struggling to run either the examples on embedded-software/bare-metal or the ones included in SoC EDS pro 20.1, trying to follow the ins...
keloke98
9 months agoHello,
Thank you for your reply, the first sd image you sent was too big and won't fit in the sd, but I followed the next steps and build the files "sdcar_a10.img" & "u-boot-splx4.sfp" in a linux VM, but I sitll getting the same error:
=> load mmc 0:1 0x10000000 application.axf
188384 bytes read in 12 ms (15 MiB/s)
=> bootelf 0x10000000
data abort
pc : [<3ffc69e2>] lr : [<3ffc6a13>]
reloc pc : [<01047a22>] lr : [<01047a53>]
sp : 3bf76f60 ip : 00000010 fp : 00000002
r10: 3ffeb6d8 r9 : 3bf7cee0 r8 : 10000000
r7 : 00000028 r6 : 00000002 r5 : 10000000 r4 : fc000046
r3 : 00000018 r2 : 00000000 r1 : 10000040 r0 : 10000040
Flags: Nzcv IRQs off FIQs off Mode SVC_32 (T)
Code: 6a2c 442c fb07 4406 (68a3) 079b
Resetting CPU ...
resetting ...
U-Boot SPL 2021.04 (Sep 02 2021 - 08:43:37 +0000)
DDRCAL: Success
DDRCAL: Scrubbing ECC RAM (1024 MiB).
KianHinT_altera
9 months agoHi keloke98
May I know what is the sdcard size that you have? The sdcard image size is around 2GB so if you're using a 4GB card that comes with the kit, it should be able to flash in. Need to rename the wic -> .img and using win32DiskImager to write the image to the card.
I noticed that your uboot is still on the old version 2021.04, could you recheck again whether you have program the sdcard correctly after you have generated the sdcard_a10.img per Radu steps?
Kian
