Agilex 5 HPS EMAC2 SWR bit in DMA_Mode Register Not Clearing
Following section 5.1.7 of the Agilex 5 Hard Processor System Technical Reference Manual, and based on what I found in U-Boot and Linux, I am writing an Ethernet driver that uses EMAC2 with an RGMII interface. I am currently stuck at the software reset using the SWR bit of the DMA_Mode register, as it remains set to 1.
Our boot flow on the AXE5-Eagle board is ATF -> U-Boot -> our OS. We use the U-Boot from https://github.com/ArrowElectronics/u-boot-socfpga/tree/socfpga_v2025.07 with some adaptations to load our OS instead of Linux.
When I read the DMA_Mode register before performing any EMAC setup in our OS, I already see the value set to 1. After bringing the PHY out of reset and setting the SWR bit again, it does not clear.
I also tried putting the EMAC into reset using the per0modrst register, setting the System Manager tsn2 register to 1 again, and then bringing the EMAC out of reset. This did not help, and after doing this I can no longer read PHY registers over MDIO.
When I load Linux instead of our OS, I can see that the reset using the SWR bit works correctly, but I can’t find what is missing in my implementation.
Any help would be greatly appreciated.
Sarah
For additional context, I read the following values before putting the EMAC2 in reset:
PHY ID1: 0x283
Main PLLGLOB: 35000103
Per PLLGLOB: 35000103
DMA_Mode: 00000001
SYSMGR_TSN2: 1
EMAC2_DWCXG_CORE_MAC_TX_CONF: 0
CLKMGR_PERPLL_EN: fffffff
CLKMGR_PERPLL_BYPASS: 0
CLKMGR_PERPLL_EMACCTL: 0
CLKMGR_CTLGRP_EMACACTR: 10001
CLKMGR_CTLGRP_EMACPTPCTR: 0
CLKMGR_CTLGRP_EXTCNTRST: 0
1 Reply
- KianHinT_altera
Closed as due to duplicate thread https://community.altera.com/discussions/soc-system/agilex-5-hps-emac2-swr-bit-in-dma-mode-register-not-clearing/350004
