Agilex 5 EMAC to EMAC : Driver error
I am trying to ping one EMAC from another, and have instantiated the following in the HPS:
These are exported to the top level, then connected as followed:
// https://www.intel.com/content/www/us/en/docs/programmable/814346/25-1/fpga-emac-i-o-signals.html module dual_emac_interface ( input wire clk, input wire rst_n, // EMAC0 Signals input wire emac0_app_rst_reset_n_wire, output wire emac0_mac_tx_clk_o_wire, // not used in 10/100 Mbps input wire emac0_mac_tx_clk_i_wire, // not used in 1/2.5 Gbps input wire emac0_mac_rx_clk_wire, output wire emac0_mac_rst_tx_n_wire, // (unused) reset for tx path output wire emac0_mac_rst_rx_n_wire, // (unused) reset for rx path output wire emac0_mac_txen_wire, output wire emac0_mac_txer_wire, input wire emac0_mac_rxdv_wire, input wire emac0_mac_rxer_wire, input wire [7:0] emac0_mac_rxd_wire, // for 10/100 Mbps designs, only bits [3:0] are used input wire emac0_mac_col_wire, // valid only when operating in half duplex input wire emac0_mac_crs_wire, output wire [2:0] emac0_mac_speed_wire, // set to 3'b011 for 1 Gbps (125 MHz) output wire [7:0] emac0_mac_txd_o_wire, // for 10/100 Mbps designs, only bits [3:0] are used // EMAC1 Signals input wire emac1_app_rst_reset_n_wire, output wire emac1_mac_tx_clk_o_wire, input wire emac1_mac_tx_clk_i_wire, input wire emac1_mac_rx_clk_wire, output wire emac1_mac_rst_tx_n_wire, output wire emac1_mac_rst_rx_n_wire, output wire emac1_mac_txen_wire, output wire emac1_mac_txer_wire, input wire emac1_mac_rxdv_wire, input wire emac1_mac_rxer_wire, input wire [7:0] emac1_mac_rxd_wire, input wire emac1_mac_col_wire, input wire emac1_mac_crs_wire, input wire [2:0] emac1_mac_speed_wire, output wire [7:0] emac1_mac_txd_o_wire ); assign emac0_app_rst_reset_n_wire = rst_n; //assign emac0_mac_tx_clk_i_wire = clk; assign emac0_mac_rx_clk_wire = emac1_mac_tx_clk_o_wire; //rxclk0=txclk1 assign emac0_mac_rxdv_wire = 1'b1; //valid held high assign emac0_mac_rxer_wire = emac1_mac_txer_wire; //rx0err=tx1err assign emac0_mac_rxd_wire = emac1_mac_txd_o_wire; //din0=dout1 //assign emac0_mac_col_wire = 1'b0; //full duplex assign emac0_mac_crs_wire = 1'b1; //never idle assign emac1_app_rst_reset_n_wire = rst_n; //assign emac1_mac_tx_clk_i_wire = clk; assign emac1_mac_rx_clk_wire = emac0_mac_tx_clk_o_wire; assign emac1_mac_rxdv_wire = 1'b1; assign emac1_mac_rxer_wire = emac0_mac_txer_wire; assign emac1_mac_rxd_wire = emac0_mac_txd_o_wire; //assign emac1_mac_col_wire = 1'b0; assign emac1_mac_crs_wire = 1'b1; endmodule
In the .dts, I have the following config (based on the dtsi provided by altera
&gmac0 { status = "okay"; phy-mode = "gmii"; fixed-link { speed = <1000>; full-duplex; }; }; &gmac1 { status = "okay"; phy-mode = "gmii"; fixed-link { speed = <1000>; full-duplex; }; };
However, when booting into linux - the drivers appear to be unhappy:
[ 26.367856] socfpga-dwmac 10810000.ethernet: Failed to reset the dma [ 26.374250] socfpga-dwmac 10810000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed [ 26.383425] socfpga-dwmac 10810000.ethernet eth0: __stmmac_open: Hw setup failed [ 26.588347] socfpga-dwmac 10820000.ethernet: Failed to reset the dma [ 26.594740] socfpga-dwmac 10820000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed [ 26.603759] socfpga-dwmac 10820000.ethernet eth1: __stmmac_open: Hw setup failed
Anyone maybe know what is the issue?
Solved: bring MAC signals up a module
- K606
Contributor
Hi @TiensungA_Altera ,
In terms of the clocking setup - I am currently doing the following:
- Feeding the output 1/2.5G port of MAC-0 to the input 1/2.5G port of MAC-1
- Feeding a custom 25MHz clock generated in the Fabric to the 10/100M ports of each MAC
I notice that in the HPS editor, there are these fields:
Which is confusing, as it makes me wonder why there is the extra option here (also documented here as not used in 1/2.5G
input wire emac0_mac_tx_clk_i_wire, // not used in 1/2.5 GbpsWhen exporting the EMAC interface from Qsys to the top level design.Upon some more digging, I found that this signal actually causes an identical error that I am seeingHowever - it is not clear from this error report how the signal should in fact be connected to avoid such an error.I have shared the relevant bitstreams here
Many thanks,
K
- TiensungA_Altera
Thanks, we will have to analyze the SOF you provided to further troubleshoot this problem.
We will revert to you when we have more insights on the issue. thanks again!
- K606
Contributor
Hi there @TiensungA_Altera - just wondering if there was any insight here? And also I would be very interested to know what method you are using to debug the designs using only the bitstreams (if that is ok?)!
Kind Regards,
K
- K606
Contributor
