Agilex 5 EMAC to EMAC : Driver error
- 1 year ago
Solved: bring MAC signals up a module
Hi @TiensungA_Altera ,
In terms of the clocking setup - I am currently doing the following:
- Feeding the output 1/2.5G port of MAC-0 to the input 1/2.5G port of MAC-1
- Feeding a custom 25MHz clock generated in the Fabric to the 10/100M ports of each MAC
I notice that in the HPS editor, there are these fields:
Which is confusing, as it makes me wonder why there is the extra option here (also documented here as not used in 1/2.5G
input wire emac0_mac_tx_clk_i_wire, // not used in 1/2.5 Gbps
I have shared the relevant bitstreams here
Many thanks,
K
Thanks, we will have to analyze the SOF you provided to further troubleshoot this problem.
We will revert to you when we have more insights on the issue. thanks again!
- K6061 year ago
Contributor
Hi there @TiensungA_Altera - just wondering if there was any insight here? And also I would be very interested to know what method you are using to debug the designs using only the bitstreams (if that is ok?)!
Kind Regards,
K
