Agilex 5 EMAC to EMAC : Driver error
- 1 year ago
Solved: bring MAC signals up a module
Hi @TiensungA_Altera ,
In terms of the clocking setup - I am currently doing the following:
- Feeding the output 1/2.5G port of MAC-0 to the input 1/2.5G port of MAC-1
- Feeding a custom 25MHz clock generated in the Fabric to the 10/100M ports of each MAC
I notice that in the HPS editor, there are these fields:
Which is confusing, as it makes me wonder why there is the extra option here (also documented here as not used in 1/2.5G
input wire emac0_mac_tx_clk_i_wire, // not used in 1/2.5 Gbps
I have shared the relevant bitstreams here
Many thanks,
K
- TiensungA_Altera1 year ago
Thanks, we will have to analyze the SOF you provided to further troubleshoot this problem.
We will revert to you when we have more insights on the issue. thanks again!
- K6061 year ago
Contributor
Hi there @TiensungA_Altera - just wondering if there was any insight here? And also I would be very interested to know what method you are using to debug the designs using only the bitstreams (if that is ok?)!
Kind Regards,
K
