15 years ago
working with Quartus 8+Synplify DSP + Synplify PRO
Hi all,
I'm working on a undergraduate final project, and I use SynplifyDSP to implement a video improvement algorithm.
The problem I faced - In my algorithm I have to access external memory in between two parts of the algorithm, so to do so I divided my Synplify DSP project into several blocks (in several files),
I then synthesized each one separately (firstly I created VHDL in Synplify DSP and then went to Synplify PRO and ran a synthesis there).
This have created several VQM's that I then inserted into Quartus.
When I then compile the project, I get errors -
things like undeclared pins etc. I think that this happens because Synplify DSP creates blocks with same names when working on different files.
I tried to combine the entire project into one file, but then when I choose retiming in synplify I didn't get the frequency I need (but when I synthesize each part on its own, I do get it to work fast enough).
My only conclusion - I must find a way to force the SynplifyDSP\PRO to generate different names, so I would be able to combine it all in Quartus, and thus hold the minimum frequency I need.
any ideas on how I can to that?
I would really appreciate any help...
thanks,
Bulzeye
P.S. sorry for my English...
    using the single vqm implementation - the simulation works.
    as regard to the input/output constraint - is it possible to constrain all the input/output at once?
    and also - how can I estimate this delay? and what if I push registers in Quartus between the blocks (in and out) - will they "stay put" there? (and then I will avoid constraining the inputs and outputs) - I think it would be ok. what do you think?
    --- Quote Start ---
    --- Quote End ---
    you can set a default delay:
    define input_delay -default 1.00 -ref {clkb:r}
    When you import the netlist and you run a "simple" P&R run Quartus will not move your register. In case you use register retiming in Quartus the registers maybe will be moved, but Quartus will take care of the timing.
    BTW: Did you check your reset and clock connectivity ?
    Kind regards
    GPK
    --- Quote Start ---
    Kind regards
    GPK
    --- Quote End ---
    ok - I'll try it.
    and I did check the connectivity.
    thanks!
