15 years agousing the single vqm implementation - the simulation works.
as regard to the input/output constraint - is it possible to constrain all the input/output at once? and also - how can I estimate this delay? and what if I push registers in Quartus between the blocks (in and out) - will they "stay put" there? (and then I will avoid constraining the inputs and outputs) - I think it would be ok. what do you think?
