13 years agoWhat is usage of "generate" in Verilog?
I am confused by the usage of "generate" in Verilog. I checked it online, find some demo codes like:
genvar index; generate for (index= 0;index < 64;index = index+1) begin : dq_delay WireDelay# ( .Delay_g (TPROP_PCB_DATA), .Delay_rd (TPROP_PCB_DATA_RD), .ERR_INSERT ("OFF") ) u_delay_dq ( .A (ddr3_dq_fpga[index]), .B (ddr3_dq_sdram[index]), .reset (~i_rst_p), .phy_init_done (init_calib_complete) ); end endgenerate But what is the difference between using "generate" and only use "For" without "generate"? If I wrote the above codes as: for (index= 0;index < 64;index = index+1) begin : dq_delay WireDelay# ( .Delay_g (TPROP_PCB_DATA), .Delay_rd (TPROP_PCB_DATA_RD), .ERR_INSERT ("OFF") ) u_delay_dq ( .A (ddr3_dq_fpga[index]), .B (ddr3_dq_sdram[index]), .reset (~i_rst_p), .phy_init_done (init_calib_complete) ); end No "generate", what is the difference? Thanks.
