13 years ago --- Quote Start --- You still need the genvar index; statement in either situation. Verilog 2005 made the generate/endgenerate keywords optional. Since the for loop appears outside of a procedural context, the extra keywords are unnecessary. The compiler is able to figure out that a for/if/case statement in a module context outside a procedural context is a generate block. Verilog is a language full of implicit defaults. But sometimes it is better to document your intent by putting the extra keywords in there. --- Quote End --- Thanks, dave_59. So that means two codes I wrote are same in Verilog 2005, right? Another question, you mentioned "for/if/case statement in a module context outside a procedural context is a generate block." Do you mean "if" or "case" out of "always"? I have never see that. Thanks.
