Here is my code, my x1 module: I only put entity and componenets since the window signal is 7*7 std_logic_vector array and all its components are multiplied and then the results are passed to parallel adder(49 words).
entity x1 is
port(
clk : in std_logic;
window : in Windows;
result_sig : out std_LOGIC_VECTOR(29 downto 0)
end x1;
architecture Behavioral of x1 is
component mult
PORT
dataa : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
datab : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (23 DOWNTO 0)
END component;
component addmult
PORT
data0x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data10x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data11x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data12x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data13x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data14x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data15x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data16x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data17x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data18x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data19x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data1x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data20x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data21x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data22x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data23x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data24x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data25x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data26x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data27x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data28x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data29x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data2x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data30x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data31x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data32x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data33x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data34x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data35x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data36x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data37x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data38x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data39x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data3x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data40x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data41x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data42x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data43x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data44x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data45x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data46x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data47x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data48x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data4x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data5x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data6x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data7x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data8x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
data9x : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (29 DOWNTO 0)
END component;
this x1 module is used as a component in top module and the window signal is passed to x1 from the following process :
process(clk)
begin
if(rising_edge(clk)) then
if(startWindowing="11") then
if(xIterator>2 and xIterator<1387 and yIterator>2 and yIterator<897) then
window(0)<=(line1(xIterator-3),line1(xIterator-2),line1(xIterator-1),line1(xIterator),line1(xIterator+1),line1(xIterator+2),line1(xIterator+3));
window(1)<=(line2(xIterator-3),line2(xIterator-2),line2(xIterator-1),line2(xIterator),line2(xIterator+1),line2(xIterator+2),line2(xIterator+3));
window(2)<=(line3(xIterator-3),line3(xIterator-2),line3(xIterator-1),line3(xIterator),line3(xIterator+1),line3(xIterator+2),line3(xIterator+3));
window(3)<=(line4(xIterator-3),line4(xIterator-2),line4(xIterator-1),line4(xIterator),line4(xIterator+1),line4(xIterator+2),line4(xIterator+3));
window(4)<=(line5(xIterator-3),line5(xIterator-2),line5(xIterator-1),line5(xIterator),line5(xIterator+1),line5(xIterator+2),line5(xIterator+3));
window(5)<=(line6(xIterator-3),line6(xIterator-2),line6(xIterator-1),line6(xIterator),line6(xIterator+1),line6(xIterator+2),line6(xIterator+3));
window(6)<=(line7(xIterator-3),line7(xIterator-2),line7(xIterator-1),line7(xIterator),line7(xIterator+1),line7(xIterator+2),line7(xIterator+3));
end if;
xIterator<=xIterator+1;
if(xIterator=1440) then
xIterator<=0;
yIterator<=yIterator+1;
if(yIterator=900) then
yIterator<=0;
end if;
end if;
end if;
end if;
end process;
Thanks for the replies, I really appriciate your helps
