Altera_ForumHonored Contributor11 years agoVideo Processing using Altera Quartus 2 Hi, i am triyng to apply a 2D convolution on a video(1440x900, 24 bit RGB) with a filter (7x7). I used multiplier and parallel add megafunctions, and created a component called 'x1'. x1 uses only %1 ...Show More
Altera_ForumHonored Contributor11 years agoHave you simulated the design? can you post up the quartus project as a .qar file?
Recent DiscussionsInterfacing Avalon Streaming FIFO IP with GTS Ethernet Hard IPInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!
