11 years agoHere is my code, my x1 module: I only put entity and componenets since the window signal is 7*7 std_logic_vector array and all its components are multiplied and then the results are passed to parallel adder(49 words).
entity x1 is port( clk : in std_logic; window : in Windows; result_sig : out std_LOGIC_VECTOR(29 downto 0) ); end x1; architecture Behavioral of x1 is component mult PORT ( dataa : IN STD_LOGIC_VECTOR (7 DOWNTO 0); datab : IN STD_LOGIC_VECTOR (15 DOWNTO 0); result : OUT STD_LOGIC_VECTOR (23 DOWNTO 0) ); END component; component addmult PORT ( data0x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data10x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data11x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data12x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data13x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data14x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data15x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data16x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data17x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data18x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data19x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data1x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data20x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data21x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data22x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data23x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data24x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data25x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data26x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data27x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data28x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data29x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data2x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data30x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data31x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data32x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data33x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data34x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data35x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data36x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data37x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data38x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data39x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data3x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data40x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data41x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data42x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data43x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data44x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data45x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data46x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data47x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data48x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data4x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data5x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data6x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data7x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data8x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); data9x : IN STD_LOGIC_VECTOR (23 DOWNTO 0); result : OUT STD_LOGIC_VECTOR (29 DOWNTO 0) ); END component; this x1 module is used as a component in top module and the window signal is passed to x1 from the following process : process(clk) begin if(rising_edge(clk)) then if(startWindowing="11") then if(xIterator>2 and xIterator<1387 and yIterator>2 and yIterator<897) then window(0)<=(line1(xIterator-3),line1(xIterator-2),line1(xIterator-1),line1(xIterator),line1(xIterator+1),line1(xIterator+2),line1(xIterator+3)); window(1)<=(line2(xIterator-3),line2(xIterator-2),line2(xIterator-1),line2(xIterator),line2(xIterator+1),line2(xIterator+2),line2(xIterator+3)); window(2)<=(line3(xIterator-3),line3(xIterator-2),line3(xIterator-1),line3(xIterator),line3(xIterator+1),line3(xIterator+2),line3(xIterator+3)); window(3)<=(line4(xIterator-3),line4(xIterator-2),line4(xIterator-1),line4(xIterator),line4(xIterator+1),line4(xIterator+2),line4(xIterator+3)); window(4)<=(line5(xIterator-3),line5(xIterator-2),line5(xIterator-1),line5(xIterator),line5(xIterator+1),line5(xIterator+2),line5(xIterator+3)); window(5)<=(line6(xIterator-3),line6(xIterator-2),line6(xIterator-1),line6(xIterator),line6(xIterator+1),line6(xIterator+2),line6(xIterator+3)); window(6)<=(line7(xIterator-3),line7(xIterator-2),line7(xIterator-1),line7(xIterator),line7(xIterator+1),line7(xIterator+2),line7(xIterator+3)); end if; xIterator<=xIterator+1; if(xIterator=1440) then xIterator<=0; yIterator<=yIterator+1; if(yIterator=900) then yIterator<=0; end if; end if; end if; end if; end process; Thanks for the replies, I really appriciate your helps
