11 years agocontinues as follows:
addmult_inst : addmult PORT MAP ( data0x => data0x_sig, data10x => data10x_sig, data11x => data11x_sig, data12x => data12x_sig, data13x => data13x_sig, data14x => data14x_sig, data15x => data15x_sig, data16x => data16x_sig, data17x => data17x_sig, data18x => data18x_sig, data19x => data19x_sig, data1x => data1x_sig, data20x => data20x_sig, data21x => data21x_sig, data22x => data22x_sig, data23x => data23x_sig, data24x => data24x_sig, data25x => data25x_sig, data26x => data26x_sig, data27x => data27x_sig, data28x => data28x_sig, data29x => data29x_sig, data2x => data2x_sig, data30x => data30x_sig, data31x => data31x_sig, data32x => data32x_sig, data33x => data33x_sig, data34x => data34x_sig, data35x => data35x_sig, data36x => data36x_sig, data37x => data37x_sig, data38x => data38x_sig, data39x => data39x_sig, data3x => data3x_sig, data40x => data40x_sig, data41x => data41x_sig, data42x => data42x_sig, data43x => data43x_sig, data44x => data44x_sig, data45x => data45x_sig, data46x => data46x_sig, data47x => data47x_sig, data48x => data48x_sig, data4x => data4x_sig, data5x => data5x_sig, data6x => data6x_sig, data7x => data7x_sig, data8x => data8x_sig, data9x => data9x_sig, result => result_sig ); datab_sig<="0000000010010011"; datab_sig1<="0000000010010011"; datab_sig2<="0000000010010011"; datab_sig3<="0000000010010011"; datab_sig4<="0000000010010011"; datab_sig5<="0000000010010011"; datab_sig6<="0000000010010011"; datab_sig7<="0000000010010011"; datab_sig8<="0000000010010011"; datab_sig9<="0000000010010011"; datab_sig10<="0000000010010011"; datab_sig11<="0000000010010011"; datab_sig12<="0000000010010011"; datab_sig13<="0000000010010011"; datab_sig14<="0000000010010011"; datab_sig15<="0000000010010011"; datab_sig16<="0000000010010011"; datab_sig17<="0000000010010011"; datab_sig18<="0000000010010011"; datab_sig19<="0000000010010011"; datab_sig20<="0000000010010011"; datab_sig21<="0000000010010011"; datab_sig22<="0000000010010011"; datab_sig23<="0000000010010011"; datab_sig24<="0000000010010011"; datab_sig25<="0000000010010011"; datab_sig26<="0000000010010011"; datab_sig27<="0000000010010011"; datab_sig28<="0000000010010011"; datab_sig29<="0000000010010011"; datab_sig30<="0000000010010011"; datab_sig31<="0000000010010011"; datab_sig32<="0000000010010011"; datab_sig33<="0000000010010011"; datab_sig34<="0000000010010011"; datab_sig35<="0000000010010011"; datab_sig36<="0000000010010011"; datab_sig37<="0000000010010011"; datab_sig38<="0000000010010011"; datab_sig39<="0000000010010011"; datab_sig40<="0000000010010011"; datab_sig41<="0000000010010011"; datab_sig42<="0000000010010011"; datab_sig43<="0000000010010011"; datab_sig44<="0000000010010011"; datab_sig45<="0000000010010011"; datab_sig46<="0000000010010011"; datab_sig47<="0000000010010011"; datab_sig48<="0000000010010011"; end Behavioral top module: library IEEE; use IEEE.numeric_std.all; use IEEE.STD_LOGIC_1164.ALL; use work.CustomTypes.all; entity FrameSelector is port( clk : in std_logic; redin : in std_logic_vector(7 downto 0); result_sig : out std_LOGIC_VECTOR(29 downto 0) --window : out windows ); end FrameSelector; architecture Behavioral of FrameSelector is --type WindowLine is array (6 downto 0) of std_logic_vector(7 downto 0); --type PixelLine is array (1439 downto 0) of std_logic_vector(7 downto 0); --type Windows is array (6 downto 0) of WindowLine; Signal window,windowtemp : Windows; signal line1,line2,line3,line4,line5,line6,line7,linetemp : PixelLine; signal StartWindowing : std_LOGIC_VECTOR(1 downto 0):="00"; signal xIterator : integer range 0 to 1439:=0; signal yIterator : integer range 0 to 899:=0; component x1 port( clk : in std_logic; window : in Windows; result_sig : out std_LOGIC_VECTOR(29 downto 0) ); end component; begin conv2d : deneme port map( clk=>clk, window=>windowtemp, result_sig=>result_sig ); windowtemp<=window; -------------------Line saving Process---------------------------------- process(clk) variable xpos : integer:=0; variable ypos : integer:=0; begin if(rising_edge(clk)) then linetemp(xpos)<=redin; xpos:=xpos+1; if(xpos=1440) then ypos:=ypos+1; xpos:=0; if(ypos=1) then line1<=linetemp; elsif(ypos=2) then line2<=linetemp; elsif(ypos=3) then line3<=linetemp; elsif(ypos=4) then line4<=linetemp; startWindowing<="11"; elsif(ypos=5) then line5<=linetemp; elsif(ypos=6) then line6<=linetemp; elsif(ypos=7) then line7<=linetemp; else line1<=line2; line2<=line3; line3<=line4; line4<=line5; line5<=line6; line6<=line7; line7<=linetemp; end if; if(ypos=900) then ypos:=0; end if; end if; end if; end process; --------------------Windowing Processs------------------------------------ process(clk) begin if(rising_edge(clk)) then if(startWindowing="11") then lot of if else statements about xpos and ypos end if; xIterator<=xIterator+1; if(xIterator=1440) then xIterator<=0; yIterator<=yIterator+1; if(yIterator=900) then yIterator<=0; end if; end if; end if; end if; end process; end Behavioral; no logic removal or any other warnings...
