11 years agoOk.
So, the fact it uses 1% means something (or most of the design) is removed. I expect this design to use most of the chip, if it actually synthesises to anything, as you havent used any rams - all your "lines" will be stored as registers. Also - this code is terrible - I have no real idea whats going on. Theres a load of multipliers and some windowing along a load of registers. Where is the source of the data? Is it really just a counter? And where is the testbench? This doesnt look like a serious design - no inputs and no outputs.
