15 years ago
VHDL: How to initialize RAM from file?
Good timings!
I find in internet-space this vhdl codе:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_TEXTIO.ALL;
USE STD.TEXTIO.ALL;
entity ram_vhdl is
Port ( clk : in STD_LOGIC;
addr : in STD_LOGIC_VECTOR (9 downto 0);
din : in STD_LOGIC_VECTOR (7 downto 0);
wen : in STD_LOGIC;
dout : out STD_LOGIC_VECTOR (7 downto 0));
end ram_vhdl;
architecture Behavioral of ram_vhdl is
type TRam is array(0 to 1023) of std_logic_vector(7 downto 0);
impure function init_bram (ram_file_name : in string) return TRam is
file ramfile : text is in ram_file_name;
variable line_read : line;
variable ram_to_return : TRam;
begin
  for i in TRam'range loop
  readline(ramfile, line_read);
  read(line_read, ram_to_return(i));
  end loop;
return ram_to_return;
end function;
signal Ram : TRam := init_bram("bram1.dat");
begin
process (clk)
begin
if clk'event and clk = '1' then
if wen = '1' then
Ram(conv_integer(addr)) <= din;
end if;
dout <= Ram(conv_integer(addr));
end if;
end process;
end Behavioral;
for initialize RAM by data from bram1.dat
But it not work in Quartus... RAM allways filled by zeros...
When i replace lines:
  end loop;
by
	ram_to_return(1) := "10000001";
	ram_to_return(2) := "10000010";
	ram_to_return(3) := "10000011";
Initialization of RAM work properly.
how to initializing ram from external file in vhdl sources?
Sorry for my bad Einglish.
    RAM initialization from files through textio library functions is only supported by ModelSim and other simulators, but not by Quartus. For synthesis, you can only use *.hex or *.mif files together with a RAM MegaFunction instance. Verilog readfunctions for binary files are supported by Quartus in constrast.
    Please raise this issue as a support request with Altera. I have previously requested it, and if others do, then maybe they will finally support it (like Xilinx do!)
