8 years agoVHDL code P2, Is anybody who can help me ?
Hi guys,
I have some code for this "project" (photo). I have no idea hot to pair this. Can You help me with port map and signals ? This code is correct ? library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity projekt is port(Up,Down, : in std_logic; A0, A1, A2, A3: out std_logic); end projekt; architecture projekt of projekt is begin s1 <= up s2 <= entity component is port (T: in std_logic Clock: in std_logic Out: out std_logic); signal tmp: std_logic; end component; Architecture Behavioral of component is begin process (Clock) begin if Clock'event and Clock='1' then if T='0' then tmp <= tmp; elsif T='1' then tmp <= not (tmp); end if; end if; end process; Out <= tmp; end przerzutnik; begin T_FF: T1 port map(T T_FF: T2 port map T_FF: T3 port map T_FF: T4 port map6 Replies
You appear to be missing all the port maps, plus I assume a copy paste error as the code is a little odd (there is a begin after the end)
Please re-post correct code and state what problems you're having - Altera_Forum
--- Quote Start --- You appear to be missing all the port maps, plus I assume a copy paste error as the code is a little odd (there is a begin after the end) Please re-post correct code and state what problems you're having --- Quote End --- I replicated only code for T flip-flop. Succession is not important bcs i know hot to sort this code. I don't know how to attribute signals and where they must be. Any suggestions? - Altera_Forum
What do you mean by "attribute signal"?
The code is full of syntax errors and incomplete. So without a reasonable code example, and a specific problem, it is hard to understand what you want.... - Altera_Forum
--- Quote Start --- What do you mean by "attribute signal"? The code is full of syntax errors and incomplete. So without a reasonable code example, and a specific problem, it is hard to understand what you want.... --- Quote End --- My teacher said : Later, you declare a component for the main unit, signals to connections, components and porting mapping ( with no logic describing how works flip flop) I know its uncomplete but want to know how it works, what is it ? And maybe i wll find code in the internet,I need it now rly, I don't asking for much, only to help with that. - Altera_Forum
The template is something like
a generic/port map looks like<libraries> entity name_of_module is <generic and port lists> end entity; architecture name_of_architecture of name_of_entity is <all aliases, signals components and constants> begin <processes, signal assignments, port maps etc> end architecture;label : name_of_component generic map( some_gen => 0 ) port map ( clk => higher_level_clock ); - Altera_Forum
--- Quote Start --- The template is something like
--- Quote End --- Finally good reply:) Thank You o much !label : name_of_component generic map( some_gen => 0 ) port map ( clk => higher_level_clock );
