14 years ago
Verilog Syntax Error
module de1sign (C, SW);
input  SW;
output  C;
assign C = SW;
assign C = SW;
endmodule
module codes (O, C, d, e, i) ; //possibility of using "i" if "1" is reserved.
input  C;
output d;
output e;
output i;
output O;
endmodule
begin    //THIS IS LINE 17
if ( C == 1'b0 && C == 1'b0);
O = d
if ( C == 1'b0 && C == 1'b1);
O = e
if ( C == 1'b1 && C == 1'b0);
O = i
end
endmodule  //Line You Asked Me to Add
module hexcircuit (O, HEX0);
input O;
output  HEX0;
always @ (O);
begin
if ( O == d )
HEX0 = 7'b100_0010;
if ( O == e )
HEX0 = 7'b011_0000;
if ( O == i )
HEX0 = 7'b100_1111;
end
endmodule
I am trying to do Lab Exercise 1 Part IV (Displaying the characters d, e, 1 on HEX0 in turn when I play with the switches.)
when i try and compile it, i get:
Error (10170): Verilog HDL syntax error at de1sign.v(17) near text "begin"; expecting a description
I am sure this is probably a very nooby error, but help is really appreciated! :)
    wrong:
    O = d
    right:
    O = d;
    OK:
    1. I have implemented FvM's changes.
    2. kaz, when I try and delete the "endmodule" at the end of module codes (line 14), compilation errors tell me that it is required. So I have kept that there.
    3. however, i don't think anybody has yet told me why i am persistently getting this error:
    Error (10170): Verilog HDL syntax error at de1sign.v(16) near text "begin"; expecting a description
    If anybody at all could clarify this error for me, and tell me how to solve it, it would be greatly appreciated.
    insert always before begin
    However you have other errors and it will help you to follow some templates.
    --- Quote Start ---
    However, I don't think anybody has yet told me why I am persistently getting this error
    --- Quote End ---
    In simple words, because you're permanently ignoring Verilog syntax rules. :(
    See below a version that compiles without errors.
    input  SW;
    output  C;
    assign C = SW;
    assign C = SW;
    endmodule
    input  C;
    output d;
    output e;
    output i;
    output reg O;
    always @ (*)
    begin
    if ( C == 1'b0 && C == 1'b0) // wrongly placed semicolon removed
    O = d;
    if ( C == 1'b0 && C == 1'b1) // wrongly placed semicolon removed
    O = e;
    if ( C == 1'b1 && C == 1'b0) // wrongly placed semicolon removed
    O = i;
    end
    endmodule
    module hexcircuit (O, HEX0, d, e, i);
    input O;
    input d;
    input e;
    input i;
    output reg  HEX0;
    always @ (O) // wrongly placed semicolon removed
    begin
    if ( O == d )
    HEX0 = 7'b100_0010;
    if ( O == e )
    HEX0 = 7'b011_0000;
    if ( O == i )
    HEX0 = 7'b100_1111;
    end
    endmodule
    --- Quote Start ---
    (FIXED CODE)
    --- Quote End ---
    Hi FvM,
    Thank you, I had just realized what I was doing wrong in terms of syntax rules. :huh:
    However, now I have to sort out all the logic errors. :(
    Once compiled and fed into my board, it does not do ANYTHING.
    If you haven't figured out already, I am supposed to toggle switches 0-2, and use them to display d,e,1 in turn on HEX0 display.
    Any ideas on what may be wrong?
    Thanks again for the help.
    --- Quote Start ---
    --- Quote End ---
    Right, I ignored reasonable logic up to now. Your design has 4 unrelated modules. I would expect a top entity linking the four. I presume, that you basically understand the operation of a hierachical design.
    --- Quote Start ---
    always @ (*)
    --- Quote End ---
    Just curiosity, what is this ? The conventional way to write is:
    always @ (C or d or e or i)
    Is always @(*) equivalent to that? Is this a new syntax added in Verilog to write sensitivity list briefly?
