8 years agoVerilog $display(" ") equivalent/does not compile in VHDL ?
I have been looking for the equivalent of the $display("") command in VHDL for some time now: main_clock: process begin CLK_CPU<='1'; wait for TClock/2; $display("test "); --errorCLK_CPU<='0'; wait for TClock/2; end process; What ever i do the lines above do not compile. (see bold) ** Error: C:/FpgaProjects/Q17/DE2_115_Shark_Serial_Component/main_bench.vhd(33): near "$": syntax error Should i include a library or is there a modelsim setting i need to change ? Lots of documents are available about the different possible parameters and Modelsim tutorials, the answer to this rather basic question i could not find. Thanks for any help, Johi.
There are really two answers to this. You can either use the report statement:
report "test"; or you can use the textio library.
OUTPUT is a built in file that is the system console. There are many tutorials out there on how to use textio. VHDL does not have equivolents of the Verilog System Calls (that start with $).use std.textio.all; .... write(OUTPUT, "test" & LF); -- test and line-feed - Altera_Forum
You cannot use Verilog/SV system tasks in VHDL. Both are different languages. In VHDL you can use the write () function to write values to console during simulation. Use the IEEE textio package and then call the write ( ) function.
Use Std.textio.all; .. .. write ( ) ; -- write values to display - Altera_Forum
Hello Tricky & eapenabrm,
Tanks for the answer, I read about write & textio, thought this was reserved for disk file io. Never thought about the OUTPUT stream. Best Regards, Johi.
