16 years agoUp & Down Counter Using Push Buttons
im trying to implement a counter that counts from 0 to 100 and vise versa. the counter must be controlled using 2 push buttons, one for incrementing and the other for decrementing for example, if 07 is displayed, pressing the increment button (push_button_1) should result in 08 being displayed or pressing the decrement button (push_button_2) should result in 06 being displayed. I tried implementing the counter using the code below (attached as well) but Quartus cannot compile it because apparently im using two distinctive clocks. Please guys, run the code n pls help me sort this problem out? Regards Dante (i only used values 00 to 07 for testing purposes) isnt there a shorter way of implementing this? otherwise i have to write statements for each and every number till 100:confused: LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY BUTTON IS PORT( PUSH_BUTTON_1 : IN STD_LOGIC; PUSH_BUTTON_2 : IN STD_LOGIC; MSD_driver : OUT STD_LOGIC_VECTOR(6 DOWNTO 0); LSD_driver : OUT STD_LOGIC_VECTOR(6 DOWNTO 0)); END BUTTON; ---------------------------------------------------------------- ARCHITECTURE a OF BUTTON IS SIGNAL PUSH_COUNTER1 :STD_LOGIC_VECTOR(2 DOWNTO 0):="000"; BEGIN PROCESS(PUSH_BUTTON_1, PUSH_BUTTON_2) BEGIN IF (PUSH_BUTTON_1'EVENT AND PUSH_BUTTON_1 ='0') THEN IF PUSH_COUNTER1 = "111" THEN PUSH_COUNTER1 <= "111"; ELSE PUSH_COUNTER1 <= PUSH_COUNTER1 + 1; END IF; ELSIF (PUSH_BUTTON_2'EVENT AND PUSH_BUTTON_2 ='0') THEN IF PUSH_COUNTER1 = "000" THEN PUSH_COUNTER1 <= "000"; ELSE PUSH_COUNTER1 <= PUSH_COUNTER1 - 1; END IF; END IF; END PROCESS; PROCESS(PUSH_COUNTER1) BEGIN CASE PUSH_COUNTER1 IS WHEN "000" => -- O=00 LSD_driver <= "1000000"; MSD_driver <= "1000000"; WHEN "001" => -- A=01 LSD_driver <= "1111001"; MSD_driver <= "1000000"; WHEN "010" => -- B=02 LSD_driver <= "0100100"; MSD_driver <= "1000000"; WHEN "011" => -- C=03 LSD_driver <= "0110000"; MSD_driver <= "1000000"; -- WHEN "100" => -- D=04 LSD_driver <= "0011001"; MSD_driver <= "1000000"; -- WHEN "101" => -- E=05 LSD_driver <= "0010010"; MSD_driver <= "1000000"; -- WHEN "110" => -- F=06 LSD_driver <= "0000010"; MSD_driver <= "1000000"; -- WHEN "111" => -- G=07 LSD_driver <= "1111000"; MSD_driver <= "1000000"; WHEN OTHERS => --23 LSD_driver <= null; --2 MSD_driver <= null; --3 END CASE; END PROCESS; END a;
