16 years agoI simply copy and paste this from one of my designs...
You need minor changes to manage up and down clocks instead of mine, which increments only. library altera; library IEEE; use IEEE.std_logic_1164.all; use ieee.std_logic_unsigned.all; use IEEE.numeric_std.all; -- for the unsigned type entity mycounter is generic ( WIDTH : integer := 8); port (CLK, RESET, LOAD : in std_logic; DATA : in unsigned(WIDTH-1 downto 0); Q : out unsigned(WIDTH-1 downto 0) ); end entity mycounter; architecture mycounter_a of mycounter is signal cnt : unsigned(WIDTH-1 downto 0); begin process(RESET, CLK) begin if RESET = '1' then cnt <= (others => '0'); elsif rising_edge(CLK) then if LOAD = '1' then cnt <= DATA; else cnt <= cnt + 1; end if; end if; end process; Q <= cnt; end architecture mycounter_a; Regards Cris
