RLou1's avatar
RLou1
8 years ago
Unavailable detection of clock edge stably
ENTITY For_V1 IS PORT(
SCLK_SLAVER : IN std_logic;
testpin : OUT std_logic
END For_V1;
ARCHITECTURE circuit OF For_V1 IS
signal clk : std_logic:=SCLK_SLAVER;
BEGIN
process(SCLK_SLAVER)
begin
if SCLK_SLAVER'event and SCLK_SLAVER = '1' then
clk <= not clk;
end if;
end process;
testpin <= clk;
END circuit;
I find clk pin is not able to catch rising edge of SCLK_SLAVER every time, I am so confused with it.
could anyone give me a suggestion for it to fix the problem?
clock rising time:60~90ns
clock frequency : 80K
Green lin is SCLK_SLAVER
orange line is testpin
  • SCLK from I2C or SPI are notoriously bad for using as clocks It is much better to treat SCLK as any other signal and sample it inside the FPGA with a much faster clock, and use the edge of SCLK as a clock enable for your other registers that also use a proper system clock.
  • Tricky's avatar
    Tricky
  • Tricky's avatar
    Tricky
    Where does SCLK_SLAVER come from? a crystal or PLL?
    If it is a logic generated clock then it can be possible that it is effected by high skew and temperature variability.
    What is clk meant to drive? IS it driving internal logic?
  • RLou1's avatar
    RLou1
    SCLK_SLAVER come from MCU, Actually it is a I2C clock.
    At first I build an I2C communication between MCU(master) and FPGA(slave) but it didn't work stably, so I simplified my code into two signals(SCLK_SLAVER and testpin ) to debug and find the issue.
    Voltage level of I2C clock is 3.3V and my FPGA I/O pin setting 3.3 LVCOMS .
    By the way, sometime it is triggered by falling edge, I don't figure it out what happen.
