RLou1
8 years agoUnavailable detection of clock edge stably
ENTITY For_V1 IS PORT( SCLK_SLAVER : IN std_logic; testpin : OUT std_logic ); END For_V1; ARCHITECTURE circuit OF For_V1 IS signal clk : std_logic:=SCLK_SLAVER; BEGIN process(SCLK_SLAVER...
- 8 years ago
SCLK from I2C or SPI are notoriously bad for using as clocks It is much better to treat SCLK as any other signal and sample it inside the FPGA with a much faster clock, and use the edge of SCLK as a clock enable for your other registers that also use a proper system clock.
Tricky
8 years agoSCLK from I2C or SPI are notoriously bad for using as clocks It is much better to treat SCLK as any other signal and sample it inside the FPGA with a much faster clock, and use the edge of SCLK as a clock enable for your other registers that also use a proper system clock.
