RLou1
8 years agoUnavailable detection of clock edge stably
ENTITY For_V1 IS PORT( SCLK_SLAVER : IN std_logic; testpin : OUT std_logic ); END For_V1; ARCHITECTURE circuit OF For_V1 IS signal clk : std_logic:=SCLK_SLAVER; BEGIN process(SCLK_SLAVER...
- 8 years ago
SCLK from I2C or SPI are notoriously bad for using as clocks It is much better to treat SCLK as any other signal and sample it inside the FPGA with a much faster clock, and use the edge of SCLK as a clock enable for your other registers that also use a proper system clock.
RLou1
8 years agoSCLK_SLAVER come from MCU, Actually it is a I2C clock.
At first I build an I2C communication between MCU(master) and FPGA(slave) but it didn't work stably, so I simplified my code into two signals(SCLK_SLAVER and testpin ) to debug and find the issue.
Voltage level of I2C clock is 3.3V and my FPGA I/O pin setting 3.3 LVCOMS .
By the way, sometime it is triggered by falling edge, I don't figure it out what happen.
