14 years agoTrying to test Filter using NCO Megafunction and Signal Tap Analyzer?
I've built a low-pass filter using Fdatool in matlab and used HDL coder in matlab to get a vhdl to simulate on hardware. i'm trying to use the NCO megafunction to generate a signal to be filtered in the lowpass filter, and use a signal tap to get the results, but no matter what i try it doesn't seem to work. here are some screen shots i have attached of what i'm doing.
i'm not sure if i'm using the wrong triggers for the signal tap(They're set to don't cares), and i'm not sure if the clock i'm using is too fast (27 MHZ). Any help will be greatly appreciated.
