14 years ago --- Quote Start --- I thought if i had all the triggers set to don't care, it wouldn't matter what change occurred at that particular node and the signal tap would activate. --- Quote End --- But you don't have them set to don't care, you have the first set to all zeros. As FvM points out though, you can just start the capture, and then stop it manually, and you would see if data was changing. Cheers, Dave
