14 years agoTesting a filter with NCO is of limited efficiency. A simple test is to inject impulse input i.e. first sample set high, others zero for some time and repeat this pattern. then you should get impulse response at output i.e. your coeffs scaled.
The best way however is to pass random data to both your design and matlab "filter" function and check for bit true performance.
