14 years agoI suspect its your trigger logic. You've got it setup to trigger when the NCO value is exactly all zeros. If you calculate how often that is likely to occur, you might find its infrequent. Try a different trigger source, eg. a push button, or Avalon-MM PIO signal.
Cheers, Dave
